2CarPros - Car Questions & Answers
2001 Acura MDX Repair Question
Topics covered: Sensor, Heater, Dent.
Asked on June 27, 2008
2001 Acura MDX Oxygen Sensors
I have replaced the original oxygen sensors, Denso, with non-OE sensors, Bosch. I cannot clear the CE nor the VTM-4 lights. I also cannot engage the VTM-4 system. On computer analysis, the DTC still indicate the O2 sensors. As an electrical engineer, I am somewhat confident I installed them correctly. The MDX runs fine with no apparent problems. I am confused. Please help.
Avatar Asked by hundriver
Answer
Replied on July 6, 2008
check to make sure that the correct sensors were installed in the right order. the primary is an air/fuel sensor and the secondary is the heated oxygen sensor.two different sensors that are not interchangeable.
Tiny Answered by jeremiah
2 questions asked
Replied on July 9, 2008
They both are 4-wire sensors. Two wires in each are listed as a heater circuit. I have rechecked the color codes and signal wires between the OEM and bosch wire color coding. I have cleared the VTM light but not the CEL. I'm now getting P0135, P0141 and P0133, indicating oxygen sensor heater circuit. The MDX still runs fine. I am perplexed.
Tiny Response from hundriver
2 questions asked
