Fuel pump location
BMOCK16
  • 1998 ACURA CL
Where is the location of a fuel pump in a 1998 acura 3.0 cl
Thursday, January 20th, 2011 AT 2:14 AM
FIXITMR
  • 9,990 POSTS
Here is a guide and diagrams to help you remove and replace the fuel pump which you can get from Amazon. Here is a guide to walk you through and diagrams below to show you on your car.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Cheers
Thursday, January 20th, 2011 AT 2:30 AM
HONDA TECH 1818
  • 536 POSTS
There is a access panel in the trunk, remove the spare tire cover and you will see the access panel with 3 screws.
Wednesday, March 30th, 2011 AT 5:32 AM
BMOCK16
  • 1998 ACURA CL
How do you access the fuel pump in the gas tank in a 1998 acura 3.0 cl, how do you replace it?
Saturday, October 20th, 2018 AT 5:04 PM (Merged)
DOCHAGERTY
  • 9,601 POSTS
Alldata says you have to remove the fuel tank to access the pump, drain the fuel first and the pump comes out the top.
KHLOW2008
  • 41,815 POSTS
Removal & Installation (3.0CL)
Release fuel pressure.
Raise and support vehicle.
Remove heat shield.
Remove fuel tank drain bolt and empty fuel tank.
Disconnect lines.
Place a jack under tank.
Remove strap nuts, and allow straps to fall free.
Disconnect all electrical connectors.
Remove fuel tank.
If fuel tank sticks, carefully pry fuel tank off mount using a pry-bar.
Remove fuel pump mounting nuts and fuel pump.
To install, reverse removal procedure.
Install drain bolt with NEW washer.
Coat drain bolt with rubber sealer (Noxrust 124B ).
Allow rubber sealer (Noxrust 124B ) to dry for 20 minutes.
GROD187
  • 1999 ACURA CL
  • 3.0L
  • V6
  • FWD
  • 219,453 MILES
Trying to figure out how to gain access to the fuel I kno where it is jus tryin to see how to get the trunk liner out to start the process of removing the old none
  • 108,179 POSTS
It isn't in the trunk. On the CL, you have to remove the tank to access it.
JCP092
  • 1999 ACURA CL
  • 3.0L
  • 6 CYL
  • 174,658 MILES
Where is the fuel pump and how do I get to it. I cant take off the back seat and don't know how to get to the fuel pump. So how do you get to it and how do you replace the fuel pump. I already have the fuel pump already I just need to find it and replace it.
  • 108,179 POSTS
The pump is in the fuel tank. I believe on your vehicle, the fuel tank needs to be removed so you can access the pump through the top of the tank.
CONETOE
  • 1999 ACURA CL
  • 4 CYL
  • 121,000 MILES
Fuel pump not working
No fire out of distributor
Check and test fuse no.5/no.2 -see below and also test the main relay
https://www.2carpros.com/forum/automotive_pictures/12900_a1_7.jpg
