Fuel pump?
STEVEL21
  • 2009 CHEVROLET AVEO
  • 1.6L
  • 105,385 MILES
I started my car and when I accelerate it doesn't go any higher than 20mph. I'm trying to figure out what the problem is. In the past I had the same problem. So I put a bottle of heet in it and worked fine. Now it just won't get any go over 20mph.
Tuesday, February 24th, 2015 AT 5:16 PM
  • 108,355 POSTS
Is the check engine light on? When was the last tune up? Have you checked fuel pump pressure? Have you checked to make sure the catalytic converter isn't plugged?
Tuesday, February 24th, 2015 AT 5:49 PM
NICOLASHERNANDEZ
  • 2005 CHEVROLET AVEO
  • 110,000 MILES
Does a Chevy Aveo has a reset button in the fuel system? Im having a problem with the fuel system. I checked the fuse and relay even I replaced the fuel pump but the pump is not working. I sprayed staring fluid in the intake and the car started for 2 seconds.
Tuesday, October 29th, 2019 AT 3:53 PM (Merged)
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,288 POSTS
Hello NICOLASHERNANDEZ
There is a couple of more fuses that need to be checked and a fuel pump replay in the under hood PDC here is a guide and some wiring diagrams to help you test and get the problem fixed.
and
Run some tests and get back to us so we can continue helping you.
Best, Ken
PD8946
  • 0 POST
Thanks for this post I had this problem and had to replace the fuel pump relay cost me $34.00 I love this site.
JUST WONDERING123
  • 2004 CHEVROLET AVEO
  • 4 CYL
  • FWD
  • 134,543 MILES
Where is the fuel pump located at on this car or does it have a reset button and is so where is the button?
JDL
  • 16,098 POSTS
Welcome to the forum, I'd use a gage and check fuel pressure before suspecting the pump, Check for good voltage and ground at the pump, if that checks out and no pump action, suspect the pump. The pump is in the tank, You should be able to access by removing the rear seat. There is no reset button, that I'm aware of.
