Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Question Forum
Auto Repair Questions by Manufacturer
Auto Repair Questions by Topic
Auto Repair First Things to Check
Auto Repair How to Repair or Service
Auto Repair Car Repair Manuals
Auto Repair How Does it Work
Auto Repair Car Repair Video Series
Auto Repair Auto Maintenance
Auto Repair Car Sound Problems
Auto Repair Auto Term Abbreviations
Popular Site Links
Auto Repair Automobile Safety Inspection
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Auto Repair Belt Routing Diagrams
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Trouble Code Table
Auto Repair How to use Diagnostic Tools
Auto Repair Smog Test Preparation
Auto Repair Hybrid Car Information
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1997 Ford Ranger Check ...
Auto Repair1998 Jeep Wrangler Heat...
Auto Repair1996 Geo Prizm Get Noth...
Auto Repair1996 Honda Civic Engine...
Auto Repair2002 Mercury Mountaineer...
Auto Repair2003 Honda Civic Air Ba...
Auto Repair1997 Isuzu Bighorn Door...
Auto Repair More Repair Topics...
Auto Repair Talk - Ask a Question, Get a Free Answer
BackGo Back RegisterRegister Log inLog in Log in to check your private messagesView your posts ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearch FAQFAQ
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2000 Chevy Astro 4.3L CSFI Vin W
Posted at Mon Mar 19, 2007 12:03 pm
By Astro, Have Donated
Give Feedback | Votes: 0
po302, po507: Replaced all of the following: fuel pump, cat. conv., fuel injectors (no.2, no.6, no.5), fuel pressure regulator, pcv valve, IAC sensor, HEI coil, plugs, wires, cap, rotor, fuel filter, all three O2 sensors, VSS, Ignition control module check was good, EGR valve stem clean, new vacuum lines, no.2 spark plug replaced again just to rule out a factory defect., TPS check good, CPS check good. I've given her lots of love. All work has been completed within the last 8mo. I should have a lean machine at this point. Exhaust doesn't really seam to have any tell-tale signs of water (white smoke) Hope to avoid replacement of head gaskets. Could the intake manifold gasket be a cause of the misfire, and not the head gasket? Since there is a PO507 with a PO302 wouldn't this be more likely?
Find a car repair manual for your Chevy Astro Repair Question.
Posted at Mon Mar 19, 2007 2:45 pm
By Service Writer, Certified 2CarPros Master Technician
Reputation: 123.6 (124) Give Feedback | Votes: 92
If you have been losing any coolant:
Let the truck set 12 hours, Have it jacked up enough to have access to the oil drain plug. Slowly back out the drain plug so there are drips coming out and catch them in a clear jar until you can confirm any coolant iis or is not present in the oil. IF not obvious, just fill the container a few inches high and allow it to set another 12 hours. Completely drain the oil. Then pressure test the cooling system with the drain plug out and catch the drainage into another clear container, letteing it set under pressure for 8 hours or so. The coolant will settle to the bottom of the container.
IF you have not been losing any coolant. compression test the #2 cylinder.
Posted at Tue Mar 20, 2007 3:47 pm
1st stroke=90
2nd=100
3rd=110
4th=about 120 and this is where it topped out.
Posted at Tue Mar 20, 2007 4:09 pm
Good results. I should have looked at the po507-high idle. Typically this is a vaccum leak source. There are couple ways to go about this. One is using an un lit propane torch and running it around the intake gasket areas, the # 2 cylinder and injector, or spraying a combustible liquid like carb cleaner. Listen for an idle change and then focus in that area.
My hunch is an intake manifold gasket problem.
Posted at Mon Apr 02, 2007 1:49 pm
By coudriet, New to the forum
What was the end result or what fixed the problem?
Posted at Sat Apr 14, 2007 11:54 am
Replaced intake gasket. Engine performance improved. BUT. Went on a road trip (1100 miles round-trip. 30 miles from arriving home, started to misfire (constant). After compression test (#6 and #4 bad), decided to replace the head gaskets. And what fun it was. Had two bent valves, HEAVY carbon build up on valves. Cleaned and inspected heads for cracks. Installed two new valves, lapped all valves, replaced valve seals. Everythings back together, fired her up, tap...tap...tap (when you lightly touch the gas pedal there is also an intermittent knock. Sounds like something is hitting the bottom of the intake. What am I looking at hear, bent push rods? Did the bearings go on the balancer shaft? I feel pretty sure some valve adjusting will clear-up the tapping, but the Knock sounds bad.
Posted at Mon Apr 23, 2007 6:15 am
I removed the valve covers today to start checking for the obvious, and I found it. I have a bent push rod on the #2 exhaust, the rocker arm bolt is broken, and so is the end of the rocker arm support (rocker pedestal or rail) whatever the correct term is for the bar they rest on. I applied enough pressure to the valve to make sure it wasn't stuck, I was able to depress it with little effort, so I don't suspect a bent valve. I don't know a whole lot in this area, and need to know what my next step should be.
Could it be that I simply didn't have the push rod seated properly on the lifter. And I can get away with installing a new support/push rod/rocker arm & bolt. Or is it likely that there is more damage below the surface. Did something else cause these parts to break (a bad lifter? camshaft?) or vice-versa did the damage I found so far, most likely damage the lifter, cam, etc.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Ferrari
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
International
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
MG
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Rover
Saab
Saturn
Scion
Seat
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Home l Help l Privacy Policy l User Agreement l About Us l Computer Repair Question l Contact Us l Link to Us l We're Hiring l Affiliate Program
  Copyright © 1999 - 2009 2CarPros.com - Professional Mechanics Online
