1998 Toyota Sienna air in radiator
DUGAN76
  • 1998 TOYOTA SIENNA
Engine Cooling problem
1998 Toyota Sienna 6 cyl Front Wheel Drive Automatic
how do I get all the air out of the cooling system? I can't get all the air out.
Wednesday, May 21st, 2008 AT 8:38 PM
Always bleed air from cooling system after replacing coolant. Set heater for maximum heat. Remove radiator cap. Loosen drain plug and remove drain bolt (if equipped) from engine block. Drain coolant reservoir. Fill coolant reservoir to MAX mark with 50/50 water-coolant mixture. Loosen bleed bolt and fill radiator up to base of filler neck. Close bleed bolt when coolant flows out without bubbles. Tighten bleed bolt. With radiator cap removed, start and operate engine to normal operating temperature. Add coolant if necessary and check for leaks.
Wednesday, May 21st, 2008 AT 9:42 PM
