head gasket estimate
2000 JEEP GRAND CHEROKEE
200,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
how many labor hours to replace the head gasket? thank you.
Dec 12, 2014 at 8:19 AM
HMAC300
  • CAR REPAIR CONTRIBUTOR
  • 48,601 POSTS
5 hours labor remove and replace head gasket
Head Gasket, R&R 4.9
NOTE (Optional Labor)
With AC, Add 0.5
Dec 12, 2014 at 9:40 AM
ALLANATHOME
Roy a local garage took my car (ha) i got the car from an x boss 10 months ago had problems starting it he didnot want to know payed £1.700 for it had to spend £1,150 local garage replace head gaskets etc then light came on the garage then told me the light was traced to this sencer thay where to call yesterday but no call i can call them if required
Allan Retired x army macanic but modern day engines wow
thanks
Feb 21, 2019 at 3:18 PM (Merged)
there are 4 o2 sensors. this is why i am asking. it could be any one of the 4.
get the code for us and why he is replacing
roy
2CP-ARCHIVES
  • 4,540 POSTS
I just replaced head gaskets and plugs, and coils. now for some reason it has a hesitation when accelerating, plus idles rough when warms up. im gettin codes for the primary/secondary coils, and misfire reading. but plugs and coils are new. all vaccums are hooked up and everythings plugged back in. its got me totally puzzled. its the 4.7
FREEMBA
  • 1,152 POSTS
post the code numbers here and I'll try to get you info which will walk you through the procedures for checking the codes.
