Mechanics
TRANSMISSION
2001 Volvo S60
Transmission problem
2001 Volvo S60 6 cyl Front Wheel Drive Automatic 89000 miles
Getting a text message: " Transmission Service Required" and " Check Engine". Car recently serviced. Transmission oil flushed and replaced. Running fine except for occasional slight surge forward after shifting to drive.
Cenzonjo
March 21, 2009.
Anytime you replace the transmission oil you should have the counter reset also. Not doing so can cause false codes to set. What I would have done first in your case is have the dealer complete a transmission control module software upgrade.
JIS001
Mar 29, 2009.
AD
