Hello! Car ran fine until battery died we tried jump starting but didnt work, so towed it home was checking it out and found that little controll unit that bolts to the coil not getting power, so checked fuses under hood, all were good, also fuel pump not working, but if you run power to the coil wire the fuel pump would work, also the check engine light and other lights that come on when you start the car does'nt come on when you turn over the ignition.
Thanks for your help!
Aug 17, 2008 at 6:38 PM
