I own a 2007 GTI and I am experiencing a misfire in cylinder 2 (slight hesitation @ low RPM's) only during cold start. Once vehicle reaches normal temp 190° or so theses symptoms go away. I replaced the plugs with the OEM replacement ones and 3 months ago had the coil packs replace under the recall. I also switched the coil from cylinder 2 to cylinder 3 and still the misfire on cylinder 2. Might this be a injector issue?
Jul 1, 2010 at 12:23 PM
