my vectras had a new brake master servo brake servo front and back rubber brake pipes abs pump front and back discs pads just had the abs pump changed with other pump and the brake peals still hitting the floor there is a little brake pedal but its near the bottom of the pedal and wat pedal is there if you keep your foot pressed on pedal it will creepaway to the floor the pedal is hard and feels good when car is not started but when you start car the pedal is down and the brakes is not good atall it slows the car down but not as it should do and the pedal feels very spongy
Jun 18, 2010 at 10:59 AM
