1.3 cdti clutch won't bleed
MARKSALLEN1980
  • 2007 VAUXHALL ASTRA
  • 1.3L
  • 4 CYL
  • TURBO
  • FWD
  • MANUAL
  • 120,000 MILES
My clutch biting point has got lower recently and then yesterday I had no clutch.
While having my fingers crossed hoping the release bearing hasn't gone through the pressure plate I thought maybe it's lost fluid and if I bleed it it will fix it.
I've had an easy bleed on the reservoir with plenty of brake fluid in, cracked off the bleed and no fluid coming out or emptying from the easy bleed. Removed the bleed plug completely and nothing. Checked it was clear, refitted a couple of turns and used a mityvac to create a vacuum on it still nothing. Regardless of if the clutch has gone or not it should bleed through. I'm thinking I have a clutch master cylinder problem, not taking in fluid.
What do you think?
Thanks
Saturday, May 2nd, 2015 AT 10:11 AM
  • 108,192 POSTS
Yes, it should bleed if you cycle the slowly about 30 times it will purge the air out automatically. Please let us know if you need anything else to get the problem fixed.
Sunday, May 3rd, 2015 AT 7:46 PM
THECIDERCITYMAN
  • 2000 VAUXHALL ASTRA
Transmission problem
2000 Vauxhall Astra Two Wheel Drive Manual 84000 miles
Hi, having probs getting into gear, when bleed clutch, gears ok, any ideas please, Thanks.
Friday, May 17th, 2019 AT 5:50 PM (Merged)
DAVE H
  • 13,383 POSTS
If you have to keep bleeding the system you must have a leak somewhere ! Possibly the seals in the slave cylinder are bad !
