Mechanics
TIMING BELT NOISE
1998 Toyota Rav4
Noises problem
1998 Toyota Rav4 4 cyl Four Wheel Drive Automatic 130 K miles
Upon cold start there is a noise coming from behind the timing belt cover. Raising the RPMs a little it goes away. No noise with engine at operating temperature. It has done this for 4 years.
http://www.2carpros.com/forum/automotive_pictures/364812_003_1.jpg
Ludwig_Dennis
June 4, 2009.
Check timing belt may be due for change or check water pump, timing tensioner bearing idler bearing or oil pump as well can cause problems
Iceboy
Aug 24, 2009.
AD
