1992 Toyota Previa cold starting problems
1992 TOYOTA PREVIA
182,000 MILES • 4 CYL • 2WD • AUTOMATIC
RICK HERMAN
Van is very hard to start in cold weather. runs very well the rest of the time including restarting after engine has been run. It seems like it needs a choke lever or button when it is cold. I was wondering if there is a sensor I could change that controls cold weather starting. Pumping the gas pedal and holding down the gas pedal do not seem to help a lot, although that is how I finally get it started. It takes almost a minute of cranking to get it started. thanks, Rick Herndon
Nov 29, 2008 at 11:01 AM
