1985 Toyota Pickup will not start/no spark from plugs
1985 TOYOTA PICKUP
BJIM
Electrical problem
1985 Toyota Pickup 4 cyl Four Wheel Drive Manual
i have a 85 toyota pickup it was idileing then just stoped i cant get a spark from the plug wires an when the switch is on i have countinuous power from the coil wire with out the engine turning.when the engine is turning there is no differance still the same countinuous power from the coil wire.when the switch is off then no power.thanks for any help u can give
Oct 1, 2010 at 4:49 PM
