2005 Toyota Highlander
Warranty problem
2005 Toyota Highlander 6 cyl Front Wheel Drive Automatic 52000 miles
My vehicle had the 5 spd auto trans. Shifts perfectly when cold. After reaches operating temp iit loses its mind. It mimicks a slipping powerglide at the first and to a lesser degree at the 2nd shift. Slow to turn into a side street and it seems to go into neutral, upon acceleration the engines revs and it doesn't engage a gear, then when does engage it may shift 2-3 times in succession. In stop and go traffic its bad.
December 19, 2009.
Hi Clinton11,
Thank you for the donation.
The transmission is shifting incorrectly and it could be due to a fault with the sensors or valve body.
Did you try to retrieve for trouble codes? You can get a free scan done at Autozone to retrieve the codes.
Does the Check Engine Lamp indicates while driving?
Have you checked the transmission fluid level and condition?
Dec 20, 2009.
