How do I set the timing mark on the crankshaft and cams
FARLOUGH
  • 1991 TOYOTA CRESSIDA
  • 211,000 MILES
What number do I put it on on the crankshaft and what postion on the cams setting
Tuesday, April 24th, 2012 AT 9:30 PM
Put engine no.1 on its compression stroke/TDC and align the Cam and Crank as indicated in the repair manual
Tuesday, April 24th, 2012 AT 9:41 PM
MRCLEATIS
  • 7 POSTS
  • 1982 TOYOTA CRESSIDA
Engine Performance problem
1982 Toyota Cressida 6 cyl Two Wheel Drive Automatic
need diagnostic help. Not firing on 2 cylinders but have spark
Friday, August 16th, 2019 AT 12:54 PM (Merged)
  • 31,938 POSTS
Hi there,
check compression, check that the plug is not fuel fouled if it is dry check the power and injection pulse, if wet check that the injector is not leaking, tart here.
Mark (mhpautos)
MRCLEATIS
  • 7 POSTS
Thank-you for taking the time and answering my questions!
My husband and I are greatly appreciative!
2 fuel injectors get no pulse. What would cause that? ECU needs replaced?
  • 31,938 POSTS
Hi there,
it is unusual for two injectors to loose pulse, I would first check that the pins in the plug are tight & clean, if OK, you may have to get the ECU tested for a fault.
Mark (mhpautos)
MRCLEATIS
  • 7 POSTS
Well Hello
I would like to start by letting you know how appreciative and grateful we are for your help and amazed at your timely responses! Damn, there might just be someone, or two, out there that really does want to help!
Did the diganostic. Didn't help. AAMCO SUKX!
Where can I get the ECU tested or how can I do that myself?
Also. Is there any other vehicles that could possibly be compatiable, or interchangable to my vehicle's ECU?
  • 31,938 POSTS
Hi there,
The ECU will be a stand alone unit, It will be to complex for you to do this your self, now as for testing, I would suggest that you contact a major parts out let as they may have this information, as I live in Australia, I'm not that sure who you can contact direct for this service, if you have no luck, re post and I will contact another Mod in the US and ask them.
Mark (mhpautos)
