2CarPros - Car Questions & Answers
Toyota Corolla Repair Question
Topics covered: Engine, Flywheel, Wheel.
Asked on July 18, 2007
Firing order
I need to know the firing order of my 1999 Corola. I took the wires off the plugs and do not know the order to return them. Please help.
Avatar Asked by Dave19
Answer
Replied on July 19, 2007
FIRING ORDER
FIRING ORDER
ApplicationFiring Order 4-Cylinder
(1)Camry & Camry Solara
(2) 1-3-4-2
Celica, Corolla, RAV4, Tacoma & 4Runner
(3) 1-3-4-2
V6
(4)Avalon, Camry, Camry Solara & Sienna
(5) 1-2-3-4-5-6
Tacoma, Tundra & 4Runner(5) 1-2-3-4-5-6
V8
(6)Land Cruiser & Tundra
7) 1-8-4-3-6-5-7-2
4cyl F/O 1342
(1)Cylinder No. 1 is located at timing belt or timing chain end of engine. Cylinder No. 4 is located at flywheel end of engine. Timing belt/chain is 2/3 in middle 4 at flywheel.
(2)System uses a Distributorless Ignition System (DIS) with 2 ignition coils. Cylinders No. 1 and 4 use the same ignition coil. Cylinders No. 2 and 3 use the same ignition coil. See Fig. 2
(3)See Fig. 4.
(4)Cylinder No. 1 is front cylinder on right side of engine when viewed from flywheel end of engine. Cylinder No. 2 is front cylinder on left side of engine when viewed from flywheel end of engine. Cylinders No. 1, 3 and 5 are on right side of engine. Cylinders No. 2, 4 and 6 are on left side of engine.
(5)System uses a Distributorless Ignition System (DIS) with 3 ignition coils. Two cylinders fire simultaneously using same ignition coil. See Fig. 3
(6)Cylinder No. 1 is front cylinder on left side of engine when viewed from flywheel end of engine. Cylinder No. 2 is front cylinder on right side of engine when viewed from flywheel end of engine. Cylinders No. 1, 3, 5 and 7 are on left side of engine. Cylinders No. 2, 4, 6 and 8 on right side of engine. See Fig. 5.
Tiny Answered by rasmataz
68 questions asked
