2001 Toyota Corolla rear stop lights
2001 TOYOTA COROLLA
STICKBALL
Electrical problem
2001 Toyota Corolla 4 cyl Front Wheel Drive Automatic
this is a follow up.i still have same problem. third light works but left and right still out. at first all three lights were not working.third light bulb burnt. replaced and now ok.fuses ok. sockets ok bulbs ok.wiring seems ok.no juice showing in either left or right.sprayed all contacts.is there another fuse i should look at? also would the brake pedal switch have anything to cause this? what else is causing this problem?
Jun 5, 2010 at 3:49 PM
