2001 Toyota Corolla Drained transmission fluid by mistake
2001 TOYOTA COROLLA
MHOLZBERG
Transmission problem
2001 Toyota Corolla 4 cyl Front Wheel Drive 101000 miles
I accidently drained the transmission fluid, and then over filled the oil spout with new oil.
Now oil dip stick is showing excess oil, while transmission dip stick is dry.
I suspect that now I have to drain all of the oil, and refill the transmission fluid.
Where is oil pan drain plug located?
Jan 9, 2010 at 8:59 PM
