1998 Toyota Corolla Oil Leak from bottom of Clutch unit
1998 TOYOTA COROLLA
280,000 MILES • 4 CYL • FWD • MANUAL
SHRINIVEL
  • 5 POSTS
Last Wk I observed oil leak from bottom of engine side then mechanic was removed gear box unit from engine and changed oil seal near clutch and also axle seal both. Again I observed oil from bottom of clutch unit then Mechanic explaining this is seems to be gear oil so we have to replace seal inside gear box or go for high viscous oil instead of 90 go for 120. Now I am totaly confused what to do ?
Apr 8, 2009 at 3:07 AM
