Anti Theft Audio System
1998 TOYOTA COROLLA
111,416 MILES • 4 CYL • FWD • AUTOMATIC
FALSEFICTION
Not having a problem presently, but for future use.
I know even if I have to replace the car's battery in the future I will need the code, which I do not have because I bought the car used. How can I go about getting a code? Would I need to contact a Toyota Dealer or is there a way or is there a way to over ride the system.
May 21, 2010 at 9:58 AM
MMPRINCE4000
  • CAR REPAIR CONTRIBUTOR
  • 8,548 POSTS
Dealer can provide assistance, you will have to show proof of ownership.
When changing battery, you can buy a device with a 9V battery that plugs into 12 outlet that will keep memory intact.
May 22, 2010 at 8:10 AM
CHRELLF
The lights flash the horn blows and the engine will not start up can someone help?
Aug 8, 2019 at 2:46 PM (Merged)
MMPRINCE4000
  • 8,548 POSTS
Here is the security system reset guide which will help you reset the system
https://www.2carpros.com/articles/how-to-reset-a-security-system
GZAVERI
I had locked my car went to my house. After sometime when I came back and tried to un-lock using my key-less it started beeping loudly as if someone had broken in.
I tried the keyless again. Opened and closed the doors to make sure that was not the issue. Also started the car in hopes that it would work.
However my key-less and my anti-theft bno longer is functioning
MMPRINCE4000
  • 8,548 POSTS
It may be as simple as a weak/bad battery in key fob.
Some autoparts stores have testers for the battery, Advance Auto Parts for one.
