1995 Toyota Corolla
Engine Mechanical problem
1995 Toyota Corolla 4 cyl Four Wheel Drive Automatic 200000 miles
how do I reset the timing belt on the car, already replaced belt?
January 13, 2009.
Not sure by what you mean by " reset". The timing belt is mechanical, if it were installed incorrectly (one tooth off), you would have some valve noise.
The crankshaft timing mark aligned, along with the camshafts timing mark (TDC #1), you then install the belt.
The ECM can be reset by disconnecting the negative battery cable for a minute or two, but if the timing belt was installed incorrectly, it would make no difference.
You would reset the computer if you were installing a new TPS (throttle position sensor). You would do this to reset the TPS voltage at closed throttle value.
Jan 14, 2009.
