1995 Toyota Corolla starting
1995 TOYOTA COROLLA
140,000 MILES • 4 CYL • 2WD • AUTOMATIC
NICHOLUS.TAYLOR
I have replaced the battery, starter, alternator, plugs, rotor, and cap. When I start the car it turns over and starts, but its runs very weak. As i give it a little gas it helps it run a bit stronger until i let off and it runs poorly. After the car is driven for a minute it seems to run fine. Could it be the fuel pump or spark plug wires, or something else?
Aug 7, 2010 at 4:44 PM
