1995 Toyota Corolla CV Joint Half Shaft
1995 TOYOTA COROLLA
182,000 MILES • 4 CYL • FWD • AUTOMATIC
WMALIK
My son car hit the curb and damaged the CV Joint Shaft, Control Arm and Tie rod end. CV Joint is broken and the portion of the shaft is still in the transmission. It should come out by pulling but it is not, are there any locks on it that I should know of.
Pulling on the housing where the roller goes should bring the shaft outside. I did not try very hard because I wanted to see if what advice I get.
Apr 1, 2008 at 1:20 PM
