1993 Toyota Corolla Sporadic Transmission
1993 TOYOTA COROLLA
MONKFISHALCHEMIST
Transmission problem
1993 Toyota Corolla Front Wheel Drive Automatic
My corolla has been having trouble starting up lately, presumably because of cold weather. I spent a whole ten minutes trying to get it started and when I finally heard it try to turn over, I pumped the gas a little bit to give it a push. It started, though a little clunkily. However, as I drove, I realized my transmission was acting funnily. When I give it some throttle, the transmission will hesitate, or do nothing, then, when I let up, it will kick into gear and once it's there, it will switch at random, like a bike when the chain jumps a gear. Even worse, when I give it more throttle to go into passing gear, I feel the initial downshift before it kicks into passing, but it stays there, constantly losing speed, just giving more gas and not gaining. Then if I let off, it kicks into gear again and starts acting sporadically. Did the startup have to do with the transmission problem? Do you think there's an electrical problem?
Dec 15, 2009 at 2:52 AM
