1992 Toyota Corolla car fail to start
1992 TOYOTA COROLLA
GEET
  • 34 POSTS
Engine Mechanical problem
1992 Toyota Corolla 4 cyl Front Wheel Drive Manual
hi thanks a lot for advice. i will go for checking of all engine wire and replace the coolant sensor. i leave in tropical country and my car had its thermostat removed as engine was heating lot. now am thinking of replacing it. is it a good idea or will the engine overheat again? here its difficult to get a new coolant sensor can i use a second hand? i also changed MAP sensor. but still the car choke and its idle is very high it never lowers after warm up. for the shime i want to postpone it if this will not choke the engine. distributor and cap have been changed
Feb 5, 2009 at 11:30 AM
