1990 Toyota Corolla Replacing Rotors
1990 TOYOTA COROLLA
80,000 MILES • 4 CYL • FWD • AUTOMATIC
ED GILL
I could not get the passenger side rotor off. So I used a wheel puller. By using the wheel puller I pushed the axle in too far, now it is crooked and it wont go back in straight into the splines. You can see from the back of the brake assembly how it pushed the cv joint out of its housing. Sure hope you can help. Thanks, Ed
May 2, 2008 at 10:07 AM
