1988 Toyota Corolla engine not running on all cylinders unt
1988 TOYOTA COROLLA
75,000 MILES • 4 CYL • FWD • AUTOMATIC
WARREN ANDERSON
This car has twin over head cams and is the SR5.When you first crank car it runs real rough.it is actually running from the distributor to the left on cylinder closest to distribtor the next one to that and very little on third one to left of distribtor.And by doing this it has a lot of gas fumes as a car has when flooded.When the car gets hot you willhear the car start running better and when it gets to normal operating temp.it runs as good as it did new. i've checked compression and it is fine I know the car is firing on the two cylinders farest from cylinder,whats my problem?
Oct 17, 2008 at 9:48 AM
