1993 Toyota Celica Possible short and/or curcuit breaker bl
1993 TOYOTA CELICA
146,000 MILES • 4 CYL • FWD • MANUAL
ALEXIA1LUV
I have a '93 Toyota Celica GT Coupe 5S-FE and I just recently installed a new battery and when doing so, the negative/positive cables were reversed and it sparked a couple of times because the previous battery had terminals on the front instead of on top.
After correcting cable placement the car started fine except for a couple of electrical things inside the car stopped working which includes (CD/Radio player, interior headlamp, both sidepanel door lights, light around Ignition key, and Trunk light)
I have checked all the fuses both inside the driver side kickpanel and under the hood Junction Block #2 (even replaced a relay) Still don't work!
Correct if I'm wrong but, I think these all run on the same circuit breaker and the manual doesn't show specific locations for each breaker so, the thing I haven't been able to do is try to reset the circuit breaker! I need help locating the correct fuse/relay/curcuit panel which controls all the above features!!
I'm at a loss as to what else it could be!!
Please help with any added info!!
Thanks,
Alexia
May 11, 2008 at 1:28 PM
