1978 Toyota Celica Fuel pump
1978 TOYOTA CELICA
48,000 MILES • 4 CYL • 2WD • MANUAL
BRADELMAN
My car will crank but not start due to lack of fuel. I suspect the fuel pump so I removed the power connector and used a voltmeter. The voltage varies from 0-10Volts and fluctuates very regularly every second.
Is this the correct form of voltage that should be present ?
Thanks
Nov 5, 2008 at 3:50 PM
