Serpentine belt diagram? I need to replace it
2002 TOYOTA CAMRY
180,000 MILES • 6 CYL • 2WD • AUTOMATIC
DERF5252
how to replace belt on 2002 toyota camry?
Dec 23, 2010 at 4:22 PM
  • CAR REPAIR CONTRIBUTOR
  • 54,354 POSTS
I have found the belt diagram for you for the 6 and 4 cylinder, here is a a guide and some diagrams (Below) to help you get the job done. https://www.2carpros.com/articles/replace-serpentine-belt Here is more information https://www.2carpros.com/diagrams/toyota/camry/2002 Here are some diagrams that will help as well. https://www.2carpros.com/images/external/94766857.gif Please let us know if you need anything else to get the problem fixed. Cheers, Ken
Sep 22, 2017 at 3:01 PM
GWAIRCOND
The belt will go on if I remove the tensioner cylinder, but then I cannot get the cylinder back on. My Haynes book does not describe parts or method clear and illistrations are poor or lacking.
Jul 21, 2020 at 11:32 AM (Merged)
LOSTINMARS
  • 222 POSTS
you took the cylinder off? no need to do that. this has a hydraulic tensioner. constant pressure on it would of collapsed it and you could of changed the belt. i honestly don't know how to put it back on, i never had the need to take one off. i can check monday when i get back to my shop.
ROBBY VANDERMARK
I have the car listed above and it has two belts very misleading
I understand. You have a split belt system. One for the A/C and another for the other accessory systems. I attached the processes for both to be replaced. Let me know if you have other questions on this. Thanks
LAURAABBE
is this something I can do in driveway???
BMRFIXIT
  • 19,053 POSTS
it can be done
MONICA.BRISTER
Hi my serpentine belt broke but I got it replaced. All pulleys seem to be rotating (nothing froze up) but headed to town and it started running hot I've never had any radiator problems or anything and was wondering what could cause this. Too broke to take it to a shop
DOCFIXIT
  • 18,828 POSTS
Is belt routed like figure?
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_573.jpg
PHILD2K
Engine Performance problem 2002 Toyota Camry 4 cyl Two Wheel Drive Automatic 100k miles Squealing belt. How do I replace? Just loosen tensioner and replace? Or loosen 2 or 3 bolts, then crank on key tensioner bolt to loosen and remove the belt? It is hard to see exactly what is needed. What are the torques of the related bolts?
https://images.2carpros.com/forum/automotive_pictures/231596_2002_Camry_4_cyl_SerpBelt_Info_2.jpg
PHILD2K
Actually, the cast tensioner assembly is located forward of the diagram shown . The left hand bolt, 14mm, must be loosened and then the right hand “bolt”, 17mm or 19mm, that is part of the casting can be pulled as shown to release the spring tension. It is easier to slide the belt off the tensioner pulley than where shown.
WAYNE DITTO
Using my Haynes manaul I am finsdng it impossible to both locate and or identify how to loosen the drivebelt to replace it. There are no adjustment screws on the alternator nor is there a flioating tension arm to lock onto. How is this belt changed?
To replace the belt you need to release the tension on the automatic belt tensioner
https://images.2carpros.com/forum/automotive_pictures/12900_belt_routing_toy_1.jpg
JDH2956
The belt broke and I do not know the configuration to replace it. There is not a diagram in the owners manual. Any idea where to get the configuration.
IMPALASS
  • 3,112 POSTS
Hello Here is the info you requested I hope you and your family have a nice Thanksgiving.
https://images.2carpros.com/forum/automotive_pictures/248015_Toyota_Camry_00023086_1.jpg
https://images.2carpros.com/forum/automotive_pictures/248015_Toyota_Camry_00023090_1.jpg
MUDASIR HUSSAIN
camry car model 2008 plz sand me belt number
SATURNTECH9
  • 30,869 POSTS
They can look it up at the Auto parts store.Are you unable to get to a auto parts store and are going to order online?If so what size engine do you have?
SRAINA
I am about to have my timing belt changed, and have been advised to replace the water pump at the same time. Is there anything else that should be changed while the timing belt and water pump are being done.
Jul 21, 2020 at 11:34 AM (Merged)
  • 31,937 POSTS
Hi there,
Normaly there is no reason to replace anything else, the water pump is not nornaly changed but if it has been there for some time it's not a bad idea. Just check that there is on oil in side the timing belt cover if so the Cam shaft seal and the front crank shaft seal should be replaced, also check the condition of the drive belts and replace any that that are suspect.
Mark (mhpautos)
