I have a 2009 toyota camry 2.4 L im having problems starting up the car in the mornings , i live in houston tx where is not so cold , the car drives perffect during the day but when i let it sit over night and i go to work in the mornings when is starts to get cold around 50 degrees the car doesnt start at all, later on the day when it warms up the car starts with no problems. the car had a short and got fixed but the engine keeps throwing a code for speed sensor which really has nothing to do with the engine not starting both of the sensors on the transmission were replaced and it keeps throwing the same code ,the sensors read my speed accurately but the code keep coming on and off they also checked all the wiring harness going to the sensors and the computer im not sure if this could be do to a bad computer . I also noticed that it shakes really bad when is on P or D and and when im driving it sometimes stalls for about 5 seconds , the car is too new for the fuel pump to be bad and it doesnt have a serviciable fuel filter, ive replaced plugs with some really good quality irimium NGK plugs which i think are the OEM plugs for the vehicle, its really getting bad to where i cant get it to start to go to work
Oct 5, 2010 at 12:55 PM
