Turn the key on and set the trip meter to odometer. Turn the key off. Depress and hold the trip meter button and turn the on while still depressing the trip reset button. The odometer screen will display 5 dashes, then 4 then 3, 2, 1, then all zeroes. Done. If it doesn't work try the same procedure starting from the "trip A" screen.
Tuesday, August 20th, 2019 AT 12:32 PM
(Merged)
