2CarPros - Car Questions & Answers
1999 Toyota Camry Repair Question
Topics covered: Blinker flasher, Fuse, Panel.
Asked on July 13, 2008
1999 Toyota Camry Signal Lights Stopped Working
Last night, my turn lights simply stopped working. They were working well, and then suddenly nothing happened when the turn lever was flipped. There is no response on the light panel or in the actual lights themselves. I've checked the fuse, and it looks fine.
One answer on here seemed to indicate that it might be the signal light flasher, but it sounded like if that were the problem, there would be different symptoms. Also, if it IS the signal light flasher, how can I locate it?
Avatar Asked by LeggsRobbins
Answer
Replied on July 13, 2008
Its behind the left kick panel
http://www.2carpros.com/forum/automotive_pictures/12900_flasher_16.jpg
Tiny Answered by rasmataz
68 questions asked
Do the symptoms sound like an car flasher problem? A friend of mine said that the blinkers were the first thing on her car that went as her alternator was dying. Does that sound possible?
(P.S. How does one give feedback/donations?)
Tiny Response from LeggsRobbins
1 question asked
Replied on July 14, 2008
Cheap fix replace the turn signal flasher-
Feedback/Donation what is it telling you when you click on it?
68 questions asked
Is the blinker flasher one of the fuses?
1 question asked
The blinker flasher is what makes it blinks-it turns it On and Off constantly
68 questions asked
