How do I change light bulb on gear shift
RUTH POYNER
  • 2003 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 190,000 MILES
Light is burnt out on gear shift.
Saturday, April 1st, 2017 AT 1:38 PM
HMAC300
  • 48,601 POSTS
See pictures. You will need a small screwdriver to pry the piece out to get to bulb. Do not let spring and button go flying.
Saturday, April 1st, 2017 AT 3:55 PM
LBROWN1982
  • 5 POSTS
  • 1998 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 195,880 MILES
I was backing my car out today and when I put it in drive the light around the D didnt light up, I was still able to drive the car fine though. Two weekends ago when I was backing out of the driveway my car turned off, but this was before I found out that I had a crack in my radiator and all my coolant had leaked out (this has since been fixed). Should I be worrying about a transmission problem or could this be something electrical? All the other gears (P, R, 2, N, L) light up when I shift to them. No check engine light or anything is on either
Thursday, November 26th, 2020 AT 12:38 PM (Merged)
FISHERMAN
  • 937 POSTS
Nothing to worry about, looks like the light indicator its burn, just needs to be replace.
The one on the dashboard or in the shifter?
Good luck!
LBROWN1982
  • 5 POSTS
The problem is in the dash board, how would I get that off and if I go to a mechanic about how much do you think it would cost me?
