Mechanics
HARD TO START THE COLD ENGINE
1998 Toyota Camry
Engine Mechanical problem
1998 Toyota Camry 4 cyl Two Wheel Drive Automatic 138000 miles
When the engine is cold, it's hard to start, I have to keep pressing gas to get it started after turn on the key, usually the initial idle speed is as low as 400 RPM, but once it's drived for a while, it runs well and could be started again easily. After more than 5 h parking, hard starting comes back. I have replaced ignition coil, valve head gasket, ignition wire and spark plugs, engine coolant temperature sensor, timing belt and water pump, nothing changes
Old98camry
April 21, 2008.
It sounds like a bad idle air control valve, is your check engine light on? It may or may not be for this one, also you may have a vacuum leak, get a can of spray gumout, spray the vac lines and maniflod area, when the idle changes, youve found the leak! You want the engine running and spray on the outside but do direct the stream onto the hoses, if it is a vacuum leak, the engine idle will change speed, then you have detected a leak, repair the vacuum leak and see how it runs!
Check the PCV, if clogged it can do this.
Merlin2021
Apr 21, 2008.
Check engine light off, no error code was found
Old98camry
Apr 21, 2008.
IAC is hard to test but you can try unplugging, and re-plugging it, it may or may not improve.
Merlin2021
Apr 21, 2008.
After replacing Idle Air Control (IAC) valve, the problem was solved! A Toyota expert told me that this is a common problem for camrys.
Thank you!
AD
Old98camry
May 4, 2008.
Your welcome!
Merlin2021
May 5, 2008.
AD
