1996 Toyota Camry won't start
1996 TOYOTA CAMRY
17,500 MILES • 4 CYL • FWD • AUTOMATIC
THOMAS WALDEN
Engine turns over but will not start
Dec 23, 2007 at 9:56 AM
MERLIN2021
  • CAR REPAIR CONTRIBUTOR
  • 17,250 POSTS
Start with the basics, and work your way up, Last tune up was? Wires plugs ALL filters? If all that is ok, check for a stuck EGR, then test fuel pump pressure, If it won't restart, determine what's missing, the engine needs three things to run, Spark at all plugs, gas to all cylinders, and compression in all cylinders, tho an engine may run lacking one in one cylinder, it won't run very well!
Dec 23, 2007 at 10:02 AM
