firing order?
2003 TOYOTA CAMRY
WASIM KHAN
i want to know the firing order of this model?
Oct 30, 2008 at 3:30 AM
BLUELIGHTNIN6
  • CAR REPAIR CONTRIBUTOR
  • 16,542 POSTS
Firing order is 1-3-4-2. Number 1 is on the passenger side, 4 is on the driver side. Here are the firing orders for both 4 and 6 cylinder engines. Check out the images (Below). Please let us know if you need anything else to get the problem fixed.
Oct 30, 2008 at 3:56 AM
CRAIGRICE
firing order - plug wire order in the distributor cap ?
Sep 24, 2020 at 11:56 AM (Merged)
HMAC300
  • 48,601 POSTS
Here is the engine ignition firing order so you can get back on the road. Firing order is 1-3-4-2 Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Sep 24, 2020 at 11:57 AM (Merged)
KCGJ0406
After researching I know that the firing order is 1342, but what do I do with that information? My wife had a friend replace the spark plugs, distributor cap, and rotor. It has been running rough ever since. Attaching a diagram.
Kavin C
Good afternoon.
Attached is a diagram for you to view for the cap and where all the wires go.
He may have them crossed or maybe he did not gap the plugs correctly.
RICK FUSARO
Changed plugs wires and distributor is miss firing when you start. I think wires are in the wrong place. from standing in front of car what is firing order?
WRENCHTECH
  • 20,761 POSTS
Check the direction of the rotation of the distributor. Bring number one up on TDC and you can look at the rotor position to determine which one is number one. https://www.2carpros.com/images/external/107336979.gif
TOMSKI68
1996 Toyota Camry 4 cyl
fireing order is 1 on passenger side or drivers side
OBXAUTOMEDIC
  • 3,711 POSTS
Hello, here is the firing order..... start from front of engine....
https://images.2carpros.com/forum/automotive_pictures/188069_96toyfirordr_1.gif
RICK FUSARO
New plugs wires cap n still runs rough did not replace rotor gaped plugs .44 1996 Camry le 2.2 liter engine lite on Rick
CACA
need firing order
  • 31,937 POSTS
Hi there,
the firing order is 1.3.4.2.
Mark (MHPAUTOS)
SHADIZAR
Engine Performance problem
1991 Toyota Camry 6 cyl Front Wheel Drive Automatic
could someone please tell me the firing order for a 1991 camry v6?
https://images.2carpros.com/forum/automotive_pictures/12900_fo_144.jpg
MYCARNEEDSHELP89
What is the proper timing setting for a 1989 Toyota Camry with a 3.0L V6 engine and what is the correct firing order? It is a station wagon if that makes a difference. I replaced the exhaust system from the catalytic converter to the muffler and found the timing to be ruff, I replaced the cap rotor plugs and wires with all NGK parts and it is still idling ruff.
Sep 26, 2020 at 12:51 PM (Merged)
See below for the engine firing order the timing is - Ignition timing is 10 deg BTDC Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Cheers
  • 31,937 POSTS
Before you set the timing make sure that the check wire is in, see pic below.
CHAPMAN06
Hi. I have a 1996 2.2L 4 cylinder. I took out the spark plug wires and forgot the replacement order.
Nov 28, 2020 at 12:11 PM
Attached is the firing order for the 2.2L. Let us know if you need more info. Thanks
Nov 28, 2020 at 4:40 PM
