1992 Toyota Camry Where is the Thermostate>
1992 TOYOTA CAMRY
399,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOHNTALLUTO
Where is the thermostate? Does it connect to one of the main hoses coming from the radiator? How do I replace it? If it goes bad does my engine overheat or is it designed to avoid engine overheating?
Every now and then my engine (as indicated by the heat gauge) runs hot but then the needle returns to normal. What causes this?
Dec 26, 2009 at 9:19 AM
