when car was running i would start the car as usual and as i was driving for like 30 to 40 minutes..depending on the day..the dash...windows nd radio and most interior electronics..like RPM gauge and all other gauges would die suddenly but car would continue to run and engine would not seize...is ithis a relay problem..or what can it be considering the car still runs but all the dash and interior electronics die including the overdrive on the transmission.because engine seems to be at higher RPM when this happens so im assuming the OD don't work..but when dash doesn't go out...OD works fine...so what can this be considering these conditions??????????????????????
Sep 25, 2010 at 4:43 PM
