Electrical problem
1988 Toyota Camry
None of My neighbors brake lights are working. I checked fuses first and even tried using a higher watt fuse. then i checked the bulbs found one was burnt but replaced and still nothing. Then i checked the box in the trunck on driver side which she said she got 3 different ones and none fixed the problem. Then i tried to see if the fuse under the hood had shorted and melted, not sure what a good one compared to a melted one looks like but it seemed to look ok. So now im down to the brake switch and just wire connections all together, or maybe the fuses are melted..what is my next step,or where would the most likely be a wiring disconnection the i missed.
1988 Toyota Camry
Sep 24, 2010 at 7:40 PM
