timing marks
1989 TOYOTA CAMRY
128,000 MILES • 4 CYL • 2WD • AUTOMATIC
BCOOKYB
How do you set the timing marks on a 1989 Toyota Camry LE 2.0L
Aug 9, 2011 at 1:52 AM
KHLOW2008
  • CAR REPAIR CONTRIBUTOR
  • 41,814 POSTS
Here is a link that shows the timing marks for your engine and the V6
https://www.2carpros.com/diagrams/toyota/camry/1989
Aug 9, 2011 at 12:30 PM
BCOOKYB
Thank you I love this site.
Aug 9, 2011 at 11:48 PM
KHLOW2008
  • 41,814 POSTS
At 11 O-clock behind the crankshaft sprocket there is a nipple on the
housing. Also there is a small V notch cut into the tone wheel behind
crankshaft sprocket one tooth to the left of Keyway for crank. Line up these to get crank @ TDC. Much faster than reinstalling cover and using timing marks.
For camshaft sprocket, refer to diagram.
Aug 10, 2011 at 11:55 AM
JORMA KNOWLES
I just bought a 1989 Toyota Camry with a V4 engine and 134,000 miles. I've been told that the timing belt should be changed soon, yet costs for such a procedure that I've been quoted seem high. Is changing a timing belt on an '89 Camry a difficult procedure, and what is a good price to get it done?
Feb 18, 2019 at 2:45 PM (Merged)
[quote:755edff73b="jorma knowles"]I just bought a 1989 Toyota Camry with a V4 engine and 134,000 miles. I've been told that the timing belt should be changed soon, yet costs for such a procedure that I've been quoted seem high. Is changing a timing belt on an '89 Camry a difficult procedure, and what is a good price to get it done?[/quote:755edff73b]
Timing belt: P/N 13568-69035=$64.00 Labor: In/Out=3hrs, Labor can vary from $80.00 to $110.00 an hr.
HTH/Good Luck
2CP-ARCHIVES
  • 4,540 POSTS
Need timing marks for belt install
FIXITMR
  • 9,990 POSTS
can you specify exact engine model?
HMAC300
  • 48,601 POSTS
what engine?
Engine Mechanical problem
1986 Toyota Camry 4 cyl Front Wheel Drive Manual
where are the timing marks suppose to line up.
  • 31,937 POSTS
Hi there , The crankshaft should be at TDC No1 cylinder and the cam has a hole that you align with a scribed mark on the backing plate, view line through hole to check alignment, see pics. mark (mhpautos)
https://images.2carpros.com/forum/automotive_pictures/61395_camry_2_1.jpg
https://images.2carpros.com/forum/automotive_pictures/61395_camry_2.jpg
ALBERTESPINO
what is the timing for a timing belt?
what is the timing for a timing belt? There's no timing for the belt if you're trying to replace it-you need a book for a gude. The igniton is the one that needs tiiming. The timing belt's job is to open and close the valves-
YANNICRISANTOS
  • 132 POSTS
Is there a diagram for timing belt marks? Need to replace timing belt
Feb 18, 2019 at 2:46 PM (Merged)
HMAC300
  • 48,601 POSTS
if engine won't start after belt replacement check for bent valves. see pic for marks.
AVDRUMMERBOY
  • 15 POSTS
Hey the timing belt just went out on my Camry I was just wondering comparatively how hard is it to change on this particular vehicle. I know that the replacement itself is not for the faint of heart and I most likely will not do it this time but was just wondering what exactly I would be getting into if I did.
Thanks in advance
Jul 27, 2020 at 12:32 PM (Merged)
  • 31,937 POSTS
Hi there,
If you have never done a timing belt before, you may have some problems as getting the front pulley off is a problem if you don't have the required tools, doing the job is not the complex a good work shop manual will give you all the pics and info you will need, now the bad news, if you have a 3FS-E fuel injected engine, you may have bent a few valves when the belt broke, this will require the head to be removed to repair this, best get a mechanic to check it out for you first.
Mark (mhpautos)
AVDRUMMERBOY
  • 15 POSTS
The 3FSE is an interference design?
  • 31,937 POSTS
Hi there,
Just re checking the timing belt guide and it says engine damage will normally occur if the belt fails, and in my experience that is the case.
mark (mhpautos)
PAT STRAT
I need the timing marks specifications and diagram for a 1987 Toyota Camry Station Wagon LE 2.0 please.
WRENCHTECH
  • 20,761 POSTS
Here are the timing marks please let us know if you need anything else, thanks for using 2Carpros https://www.2carpros.com/images/external/78900676.jpg.gif
  • 54,354 POSTS
Hey,
Here is another image to help you. Let us know how it goes
Best, Ken
