Check the radiator if its clogged and water pump circulating coolant thru out the engine engine if okay could be airlock try bleeding it don't work get it block and pressure tested to rule out a blown headgasket, cracked head or block.
SPONSORED LINKS
Tuesday, June 8th, 2010 AT 2:03 AM
