Fuel Filter
TOYOTA 4RUNNER
BKEVIN
Where is the fuel filter located on a 1991 Toyota 4Runner SR5 4x4 2.4L 4 cylinder?
Apr 23, 2007 at 9:06 PM
  • CAR REPAIR CONTRIBUTOR
The Fuel Filter is Located at the right side of the engine above the starter motor.
NOTE: If vehicle has been operated within an hour, the fuel system is probably under pressure and requires caution when removing filter union bolts.
REMOVAL:
1. Locate the fuel filter on the right side of the engine.
2. Slowly loosen the filter union bolts. Some gasoline may escape, so ensure that the potential for fire is minimized.
3. Remove the union bolts and four gaskets.
4. Loosen filter clamp and slip filter from clamp.
INSTALLATION:
1. Slip new filter into clamp. Ensure that flow arrows are in the correct direction.
2. Position filter in the middle of the clamp and tighten filter clamp.
Replacing The Fuel Filter
3. Reinstall both union bolts with four new gaskets.
4. Torque union bolts to 18 Nm (13 ft lbs). DO NOT overtighten union bolts.
5. Clean any gasoline that may have escaped.
6. Start the engine and check for fuel leaks.
Apr 24, 2007 at 4:59 AM
DCOLLINS12
Engine Performance problem
1995 Toyota 4Runner 6 cyl Four Wheel Drive Automatic
Does my 4Runner have a fuel filter. If so, where is it located? Can't find the filter in auto stores.
Apr 17, 2019 at 6:35 PM (Merged)
Fuel Filter Location
https://images.2carpros.com/forum/automotive_pictures/12900_ff_29.jpg
Fuel Lines And Components
https://images.2carpros.com/forum/automotive_pictures/12900_ff1_9.gif
The Fuel Filter is located on the right frame rail underneath the passenger compartment.
JBTEEHEE
1990 Toyota 4Runner 6 cyl Four Wheel Drive Automatic
trying to locate and change fuel filter
https://images.2carpros.com/forum/automotive_pictures/12900_fuelfiltertoy_1.gif
The Fuel Filter is located on the right frame rail underneath the passenger compartment. NOTE: If vehicle has been operated within an hour, the fuel system is probably under pressure and requires caution when removing filter union bolts. REMOVAL: 1.Locate the fuel filter on the right frame rail underneath of the passenger compartment. 2.Slowly loosen the filter union bolts. Some gasoline may escape, so ensure that the potential for fire is minimized. 3.Remove the union bolts and four gaskets. 4.Loosen filter clamp and slip filter from clamp. INSTALLATION: 1.Slip new filter into clamp. Ensure that flow arrows are in the correct direction. 2.Position filter in the middle of the clamp and tighten filter clamp. 3.Reinstall both union bolts with four new gaskets. 4.Torque union bolts to 18 Nm (13 ft lbs) . DO NOT overtighten union bolts. 5.Clean any gasoline that may have escaped. 6.Start the engine and check for fuel leaks.
SMID
  • 5 POSTS
how do I change the fuel filter on my 98 toyota 4 runner?
Left side of engine block, above and ahead of the starter.
SMID
  • 5 POSTS
is this difficult to change? does the gas tank have to be empty? do you know where I can get pictures with specific instructions?
Its not difficult and you don't have to empty out the fuel tank
Tacoma, T100 & 4Runner
Depressurize the fuel system befroe removing fuel filter
Disconnect fuel pump electrical connector located on top of fuel tank. Start engine and allow engine to idle until engine stalls. Turn ignition off. Reinstall fuel pump electrical connector.
Disconnect negative battery cable. Place suitable container under fuel line connection. Cover fuel line connection with shop towel. Slowly loosen fuel line connection, allowing any fuel pressure to be released. Once fuel pressure is released, fuel system components may be serviced.
SMID
  • 5 POSTS
thank you very much for the info! I really appreciate it!
ARMANDOPO
how to change the fuel filter 4runner 2007
DOCFIXIT
  • 18,828 POSTS
Filter part of fuel pump in tank generaly not servised untill pump failure. Can access through rear floor service cover
RANDY MOORE
I have been unable to find the fuel filter on my 4 runner. I saw on one of the entries for a 1985 that it is in the top of the gas tank. Is that where i need to look for mine?
1986 Toyota Truck 4 Runner 4WD L4-144.4 2366cc 2.4L SOHC (22R-E) Engine Compartment Fuel Filter
https://images.2carpros.com/forum/automotive_pictures/12900_ff_5.gif
Fuel Tank Pump and Filter
https://images.2carpros.com/forum/automotive_pictures/12900_ff1_5.jpg
https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
