1997 Mitsubishi 3000 GT clutch has gone out
1997 MITSUBISHI 3000GT
133,000 MILES • 5 CYL • 2WD • MANUAL
2CP-ARCHIVES
  • 4,540 POSTS
1997 Mitsubishi 3000 GT mileage: 133,000. My car is a five speed standard and I believe that the clutch has gone out. The car will go into gear, but when the clutch pedal is let out  the car will not move. I also smell a burning smell such as a clutch going out. What is your recommendation and if it is the clutch is this a job that only a dealer should do? If so, do you have an idea as to what the total cost would be, parts, labor, etc. I'm trying to get an idea since my parents are making me save up for the total repair.
Nov 10, 2010 at 10:09 PM
2CP-ARCHIVES
  • 4,540 POSTS
From what you have described, it sounds like your clutch has failed. Most independent repair service centers should be able to do the work for you. We would highly recommend replacing the clutch with new parts. As for the cost, it varies from region to region. Call local service centers for cost comparisons
Nov 10, 2010 at 10:11 PM
