2CarPros - Car Questions & Answers
1998 Subaru Other Repair Question
Topics covered: Gas, Head gasket, Oil pan.
Asked on August 30, 2007
Oil Leaks 98 GT 2.5
I recently blew the head gaskets and had them replaced along with all of the Belts etc. My car is now leaking oil pretty bad from below. When I park my car and return there is a puddle towards the front on the passanger side (same place where water condenses and leaks off when running AC) I am pretty sure that I need to replace the oil pan seal but there also seems to be oil on the top of my motor. I am wondering if my mechanic did not replace any seals etc. that are normally suppose to be done with the head gasket replacement that would add to my leaking oil. I know for a fact that the oil pan seal did not leak before blowing the head gaskets. Are valve cover gaskets normally done with the head gasket repair?
Avatar Asked by jcoheley
No Answer Yet
