2002 Subaru Legacy
2002 SUBARU LEGACY
TIFFSZTOYZZ
Engine Mechanical problem
2002 Subaru Legacy 4 cyl
what is the name of the sensor that is located right below the throttle of the carb. i recently had all the gaskets redone due to a head gasket leak and now its leaking oil on both sides of the block. did the dye test and revealed nothing. i think the oil is coming from that sensor butI cant figure out which one it is. I dont think its my oil pressure sensor cuz that is right by my alternator. thank you
Sep 12, 2010 at 3:13 PM
