Firing order please?
VIDEO
  • 2001 BUICK CENTURY
Six cylinder 3.1L engine two wheel drive automatic.
I just changed spark plugs and my car now is in rough idle and sputtering. I used Autolite platinum. I want to know the spark plug order. I numbered my wires and I may have messed it up. Is it -2-3 along the fire wall with 1 being on the passenger side? And 4-5-6 in the front with 6 being on the passenger side. I assume that is to correspond with the numbers on the distributor cap.
Last time I changed plugs I changed wires.
Tuesday, August 24th, 2010 AT 9:24 AM
JDL
  • 16,098 POSTS
The part that says front in the diagram is passenger side. You have a coil pack, no distributor, correct?
https://www.2carpros.com/forum/automotive_pictures/170934_century_firing_order_1.jpg
Thursday, October 12th, 2017 AT 3:00 PM
VIDEO
  • 16 POSTS
JDL,
Thanks for the diagram. I had two and four switched. Yes, I have a coil pack. I mistakenly said distributor, also working on my old gas tractor.
KYLE DUBY
  • 2000 BUICK CENTURY
  • 120,000 MILES
I need a diagram and firing order for a my car listed above. I am not completely sure they were right to begin with, and I cannot find my owners manual. I just want to make sure.
Thursday, November 26th, 2020 AT 10:17 AM (Merged)
WRENCHTECH
  • 20,758 POSTS
The firing order is 5 2 3 6 4 1
https://www.2carpros.com/images/external/84817708.gif
https://www.2carpros.com/images/external/148709066.gif
DISVNVET
  • 6 POSTS
  • 6 CYL
  • FWD
  • 90,000 MILES
Have a century with 3.1. OBD-II says #6 cyl misfire. Looking at the engine from front of car, which cyl is #6.
Towards the firewall, the plug wire is broken. Again, it is the firewall side of engine, furtherest on the left near alternator.
I think this is #5 so why is it showing #6 misfire. A diagram would help.
Since it is not my car, I don't want to buy a manual.
DOCFIXIT
  • 18,828 POSTS
Fire wall side front to back 1-3-5. Radiator side front to back 2-4-6.
XAVIERTORRES
  • 1999 BUICK CENTURY
  • 6 CYL
  • FWD
  • 107,129 MILES
Firing order for 99 buick century
Here is the engine ignition Firing Order 1-2-3-4-5-6 Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
SAM.NEVE
Electrical problem 6 cyl Two Wheel Drive Automatic 100K+ miles
I was replacing the plug wires and replaced them. The car is not running well at all now and I fear to drive it.
2CARPRO JACK
  • 11,533 POSTS
Firing order 3.8.
https://www.2carpros.com/forum/automotive_pictures/1639_38_1.jpg
firing order 3.1, 3.4.
https://www.2carpros.com/forum/automotive_pictures/1639_3134_1.jpg
MARIE HARTJE
  • 1993 BUICK CENTURY
  • 3.3L
  • 6 CYL
  • 120,000 MILES
Spark plug wires may have been crossed.
Thursday, November 26th, 2020 AT 10:18 AM (Merged)
OBXAUTOMEDIC
  • 3,711 POSTS
Below is picture of firing order.
Hope this helps.
Mark
MIGMANR
  • 6 CYL
  • FWD
  • 198,000 MILES
What is the firing order and which side is number 1 plug on?
LEGITIMATE007
  • 5,121 POSTS
Firing order and wire order for buick 3.3 v6
https://www.2carpros.com/forum/automotive_pictures/88091_buick_33_1.jpg
LAKEFRONTLIVIN
How come the #4 plug wire is going to cylinder #2. I hope I'm reading the diagram right?
Thanx
ZACKMAN
  • 4,202 POSTS
Try one of these.
Late 92 (sometimes known as 1993)
https://www.2carpros.com/forum/automotive_pictures/55316_92centuryfiring_1.jpg
1993
https://www.2carpros.com/forum/automotive_pictures/55316_93centuryfiring_1.jpg
DENEANLP
  • 1992 BUICK CENTURY
Engine Mechanical problem
1992 Buick Century 6 cyl Two Wheel Drive Automatic
I need a engine diagram and firing order for the 1992 Buick Century Special edition.
JDL
  • 16,098 POSTS
Hello, I came across this.
https://www.2carpros.com/forum/automotive_pictures/170934_buick_century_special_1.jpg
DENEANLP
which is the Number one spark plug when you are standing in front of the car. Wires were pulled off my car and I don't which is number one or two or six. And what is the firing order.
JDL
  • 16,098 POSTS
3.3 litre engine
https://www.2carpros.com/forum/automotive_pictures/170934_33_litre_engine_1.jpg
Firing order is 165432.
