The motor turns over and I can smell fuel, I suspect that its not getting spark and its probably the coil. I have only worked on motors with spark plugs not these new fancy coil things, I was not sure if they are able to be replaced by the average joe mechanic or if I should take it to a dealer, or if there is something else I should check first. thanks
Jan 21, 2009 at 5:16 PM
