Mechanics
92 WINDSHIELD WIPER STOPPED WORKING.
1992 Saturn Other
Are there any known common failures that would stop the front wipers from working?
Is there a fuse? If so where might I find one. This is my daughters car and she can not afford a major expense.
Suggestions?
Awilliam
January 5, 2006.
It could be a fuse, the fuse will be with the fuse box. Usually under the drivers side dash?Not quite sure. If its not a fuse then the motor for the wipers went. It dosnt cost to much if you get it from a junk yard. This should be a easy/cheap fix. Eather way.
AD
Dodge89
Jan 17, 2006.
Problem turned out to be the the nut on the drive motor came off and the linkage popped off. Just had to reattach it.
Thank you
Awilliam
Jan 18, 2006.
AD
